Ir para o conteúdo principal
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
O que você precisa
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: passo 1, imagem 1 %32
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 2, imagem 1 %32
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
    Pergunte ao FixBot
    Comentar
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 3, imagem 1 %32
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
    Pergunte ao FixBot
    Comentar
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 4, imagem 1 %32
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
    Pergunte ao FixBot
    Comentar
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 5, imagem 1 %32 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 5, imagem 2 %32
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
    Pergunte ao FixBot
    Comentar
Conclusão
2Comentários do guia
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - Responder Compartilhar
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 2,990
