Ir para o conteúdo principal
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
O que você precisa
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: passo 1, imagem 1 %32
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 2, imagem 1 %32
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 3, imagem 1 %32
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 4, imagem 1 %32
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 5, imagem 1 %32 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: passo 5, imagem 2 %32
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
Conclusão
2 comentários
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - Responder
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 2,489
