Ir para o conteúdo principal
Sony VAIO SVE14AJ16L RAM Replacement
O que você precisa
  1. Sony VAIO SVE14AJ16L RAM Replacement, RAM: passo 1, imagem 1 %32
    • Turn your laptop off before starting.
    • Turn the laptop upside down onto the closed lid so that the bottom is facing you.
    Pergunte ao FixBot
    Comentar
  2. Sony VAIO SVE14AJ16L RAM Replacement: passo 2, imagem 1 %32 Sony VAIO SVE14AJ16L RAM Replacement: passo 2, imagem 2 %32
    • Locate and remove the lone screw on the RAM cover with a Phillips #0 head screw driver.
    • Carefully pry the RAM cover up.
    • There will be some resistance, so use strength and not speed to remove the cover.
    Pergunte ao FixBot
    Comentar
  3. Sony VAIO SVE14AJ16L RAM Replacement: passo 3, imagem 1 %32 Sony VAIO SVE14AJ16L RAM Replacement: passo 3, imagem 2 %32 Sony VAIO SVE14AJ16L RAM Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    iFixit Opening Tool
    $1.99
    • With the cover removed, peel back the black protective plastic to expose one of the two RAM sticks.
    • Make sure not to touch any part of the blue board itself, and only handle the stick from it's edges.
    • Gently, but firmly push back the two side anchors that hold in the RAM using either an iFixit Opening Tool or your fingernails.
    Pergunte ao FixBot
    Comentar
  4. Sony VAIO SVE14AJ16L RAM Replacement: passo 4, imagem 1 %32 Sony VAIO SVE14AJ16L RAM Replacement: passo 4, imagem 2 %32
    • Once both anchors are released from the RAM stick, the stick will spring up at an angle
    • Finally, carefully pull the RAM stick away from the laptop at the same angle it is sitting at.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 38
Ao todo: 949
