Ir para o conteúdo principal
Sony VAIO PCG-933A Floppy Disk Drive Replacement
  1. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 2, imagem 1 %32 Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 2, imagem 2 %32 Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 2, imagem 3 %32
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Floppy Disk Drive: passo 3, imagem 1 %32
    • With the laptop facing you, turn the laptop upside down.
  4. Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 4, imagem 1 %32 Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 4, imagem 2 %32 Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 4, imagem 3 %32
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  5. Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 5, imagem 1 %32
    • To replace, insert the new floppy disk drive with the wording facing down.
Conclusão
Sara Lillard
Membro desde: 04/11/11
165 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 12-36, Maness Spring 2011 Membro de Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,992
