Ir para o conteúdo principal
Sony VAIO VPCEE26FX RAM Replacement
O que você precisa
  1. Sony VAIO VPCEE26FX RAM Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VPCEE26FX RAM Replacement, Battery: passo 1, imagem 2 %32
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX RAM Replacement: passo 2, imagem 1 %32 Sony VAIO VPCEE26FX RAM Replacement: passo 2, imagem 2 %32
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX RAM Replacement, RAM: passo 3, imagem 1 %32
    • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
    • This screw will not come out all the way, but will remain attached to the cover instead.
  4. Sony VAIO VPCEE26FX RAM Replacement: passo 4, imagem 1 %32
    • Remove the cover which will reveal the two RAM sticks.
  5. Sony VAIO VPCEE26FX RAM Replacement: passo 5, imagem 1 %32 Sony VAIO VPCEE26FX RAM Replacement: passo 5, imagem 2 %32 Sony VAIO VPCEE26FX RAM Replacement: passo 5, imagem 3 %32
    • Push the two tabs holding the RAM sticks in place, away from each other.
    • The first RAM stick will pop up out of place. Remove it away from its position.
  6. Sony VAIO VPCEE26FX RAM Replacement: passo 6, imagem 1 %32 Sony VAIO VPCEE26FX RAM Replacement: passo 6, imagem 2 %32 Sony VAIO VPCEE26FX RAM Replacement: passo 6, imagem 3 %32
    • Push the two tabs holding the second RAM stick in, away from each other.
    • The second RAM stick will pop up out of place. Remove it away from its position.
Conclusão
Equipe
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 Membro de UMass Dartmouth, Team S2-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S2G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 1,385
