Ir para o conteúdo principal
Sony VAIO VPCEE26FX Battery Replacement
  1. Sony VAIO VPCEE26FX Battery Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VPCEE26FX Battery Replacement, Battery: passo 1, imagem 2 %32
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Battery Replacement: passo 2, imagem 1 %32 Sony VAIO VPCEE26FX Battery Replacement: passo 2, imagem 2 %32
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
Conclusão
Equipe
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 Membro de UMass Dartmouth, Team S2-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S2G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 702
