Ir para o conteúdo principal
Sony Tablet S Battery Replacement
O que você precisa
  1. Sony Tablet S Battery Replacement, Battery: passo 1, imagem 1 %32 Sony Tablet S Battery Replacement, Battery: passo 1, imagem 2 %32
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Battery Replacement: passo 2, imagem 1 %32
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Battery Replacement: passo 3, imagem 1 %32 Sony Tablet S Battery Replacement: passo 3, imagem 2 %32
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Battery Replacement: passo 4, imagem 1 %32
    • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
  5. Sony Tablet S Battery Replacement: passo 5, imagem 1 %32
    • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
    • Use caution when removing the cable, as the socket is very fragile.
  6. Sony Tablet S Battery Replacement: passo 6, imagem 1 %32
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
  7. Sony Tablet S Battery Replacement: passo 7, imagem 1 %32
    • Slide the bottom grey cover piece away from the body and remove it.
    • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
  8. Sony Tablet S Battery Replacement: passo 8, imagem 1 %32
    • Remove the five 4mm Phillips #000 screws.
    • Remove the two 5mm Phillips #000 screws holding the charger in place.
  9. Sony Tablet S Battery Replacement: passo 9, imagem 1 %32 Sony Tablet S Battery Replacement: passo 9, imagem 2 %32 Sony Tablet S Battery Replacement: passo 9, imagem 3 %32
    • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
    • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
  10. Sony Tablet S Battery Replacement: passo 10, imagem 1 %32 Sony Tablet S Battery Replacement: passo 10, imagem 2 %32
    • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
  11. Sony Tablet S Battery Replacement: passo 11, imagem 1 %32
    • Remove the three 5mm Phillips #0 screws securing the original battery.
  12. Sony Tablet S Battery Replacement: passo 12, imagem 1 %32 Sony Tablet S Battery Replacement: passo 12, imagem 2 %32
    • Use the spudger to pop the battery loose and remove the battery.
Conclusão
4 outras pessoas executaram este guia.
Austin Mann
Membro desde: 09/28/16
287 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-5, Passmore Fall 2016 Membro de USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 41
Duração total: 2,594
