Ir para o conteúdo principal
Sony TCM-919 Cassette-Corder Speaker Replacement
O que você precisa
  1. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Battery Cover: passo 1, imagem 1 %32
    • Turn the device around so that the back cover is facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Back Casing: passo 2, imagem 1 %32
    • Remove the 5, 5.95mm screws as indicated in the picture.
  3. Sony TCM-919 Cassette-Corder Speaker Replacement, Desolder Speaker Wires: passo 3, imagem 1 %32 Sony TCM-919 Cassette-Corder Speaker Replacement, Desolder Speaker Wires: passo 3, imagem 2 %32
    • Look to the back of the top cover.
    • Desolder the two wires from the speaker.
  4. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Speaker: passo 4, imagem 1 %32 Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Speaker: passo 4, imagem 2 %32
    • Squeeze the two prongs holding the speaker in place and remove the metal piece.
    • Remove the speaker by gently lifting it up from the cover and pulling.
Conclusão
Marygayle Martin
Membro desde: 10/23/14
506 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 4-3, Williams Fall 2014 Membro de Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 507
