Ir para o conteúdo principal
Sony TCM-919 Cassette-Corder Motherboard Replacement
O que você precisa
  1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Back Cover: passo 1, imagem 1 %32
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Motherboard Replacement, Back Cover Screw Removal: passo 2, imagem 1 %32
    • Remove the 5 5.95mm screws as indicated in the picture using the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: passo 3, imagem 1 %32 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: passo 3, imagem 2 %32
    • Locate the 3-digit tape counter and gently push the tabs apart releasing the counter.
    • Pull the 3-digit tape counter out.
    • Remove the rubber band attaching the 3-digit tape counter to the cassette head.
  4. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: passo 4, imagem 1 %32 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: passo 4, imagem 2 %32
    • Remove the screws as indicated in the picture using the Phillips Head screwdriver.
    • Pull the loosened motor out of the device, and set the motor aside.
  5. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: passo 5, imagem 1 %32 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: passo 5, imagem 2 %32 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: passo 5, imagem 3 %32
    • Removes the 3, 5.95mm screws using the Phillips Head screwdriver as indicated by picture 1.
    • Push firmly on the tabs and lift the tape deck out.
    • Set the tape deck aside.
  6. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motherboard Screws: passo 6, imagem 1 %32
    • Remove the 2 5.95mm screws as indicated by the picture using the Phillips Head screwdriver.
  7. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Epoxy: passo 7, imagem 1 %32
    • Remove the epoxy completely from the motherboard so that the wires underneath the epoxy can move freely.
  8. Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: passo 8, imagem 1 %32 Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: passo 8, imagem 2 %32
    • Remove the motherboard from case.
    • Flip the motherboard around so that the metallic green side is facing you.
    • Desolder the points indicated in picture 2. This should free the wires connected to the motherboard.
    • Remove the motherboard by pulling it out of the device cavity.
Conclusão
Marygayle Martin
Membro desde: 10/23/14
506 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 4-3, Williams Fall 2014 Membro de Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 1,718
