Ir para o conteúdo principal
Sony TCM-919 Cassette-Corder Microphone Replacement
O que você precisa
  1. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove battery Cover: passo 1, imagem 1 %32
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Back Casing: passo 2, imagem 1 %32
    • Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
  3. Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: passo 3, imagem 1 %32 Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: passo 3, imagem 2 %32
    • Look to the back of the top cover.
    • Desolder the two wires connected to the mircophone using the soldering station.
  4. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: passo 4, imagem 1 %32 Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: passo 4, imagem 2 %32
    • Gently remove the rubber top from the two plastic knobs that hold the microphone in place.
    • Remove the microphone by pulling up.
Conclusão
Marygayle Martin
Membro desde: 10/23/14
506 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 4-3, Williams Fall 2014 Membro de Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 503
