Ir para o conteúdo principal
Sony Smart Watch SW2 Motherboard Cover Replacement
O que você precisa
  1. Sony Smart Watch SW2 Motherboard Cover Replacement, Motherboard Cover: passo 1, imagem 1 %32 Sony Smart Watch SW2 Motherboard Cover Replacement, Motherboard Cover: passo 1, imagem 2 %32
    • Push down the smart watch housing with both thumbs while holding the outer frame.
    • Note that the power button will fall off of the frame. Set it aside in a safe place with the wristband.
  2. Sony Smart Watch SW2 Motherboard Cover Replacement: passo 2, imagem 1 %32 Sony Smart Watch SW2 Motherboard Cover Replacement: passo 2, imagem 2 %32
    • Detach the screen using the plastic prying tool.
    • Detach the LCD screen from the motherboard by pulling the ribbon cable very carefully and slowly.
  3. Sony Smart Watch SW2 Motherboard Cover Replacement: passo 3, imagem 1 %32 Sony Smart Watch SW2 Motherboard Cover Replacement: passo 3, imagem 2 %32
    • Using a the Spudger, remove the cover. Work your way around to find the most convenient place to open it.
Conclusão
Mohammed Alshamrani
Membro desde: 03/21/18
232 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G2, Freund Spring 2018 Membro de IUPUI, Team S2-G2, Freund Spring 2018
IUPUI-FREUND-S18S2G2
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 905
