Ir para o conteúdo principal
Sony Smart Watch SW2 Display Assembly Replacement
O que você precisa
  1. Sony Smart Watch SW2 Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32
    • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
    • Set aside the power button and watch band as they are no longer needed for further disassembly.
  2. Sony Smart Watch SW2 Display Assembly Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  3. Sony Smart Watch SW2 Display Assembly Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  4. Sony Smart Watch SW2 Display Assembly Replacement: passo 4, imagem 1 %32
    • Set aside the detached LCD screen to access the battery.
Conclusão
To reassemble your device, follow these steps in reverse order.
Vincent Shiue
Membro desde: 01/22/18
256 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G5, Freund Spring 2018 Membro de IUPUI, Team S1-G5, Freund Spring 2018
IUPUI-FREUND-S18S1G5
Membros da 3
Autoria de 2 guias
Um comentário
whwre can I get the LCD screen for SW2?
faizal ahamed - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 22
Duração total: 2,913
