Ir para o conteúdo principal
Sony SS-CCP1 Speaker Replacement
O que você precisa
  1. Sony SS-CCP1 Speaker Replacement, Screen: passo 1, imagem 1 %32 Sony SS-CCP1 Speaker Replacement, Screen: passo 1, imagem 2 %32 Sony SS-CCP1 Speaker Replacement, Screen: passo 1, imagem 3 %32
    • Pull screen cover from the edges for removal. This will not require much effort.
  2. Sony SS-CCP1 Speaker Replacement, Speaker: passo 2, imagem 1 %32 Sony SS-CCP1 Speaker Replacement, Speaker: passo 2, imagem 2 %32
    • Remove the seven 18.06mm PH1 screws.
  3. Sony SS-CCP1 Speaker Replacement: passo 3, imagem 1 %32 Sony SS-CCP1 Speaker Replacement: passo 3, imagem 2 %32 Sony SS-CCP1 Speaker Replacement: passo 3, imagem 3 %32
    • Remove the crimps from the tweeter speaker.
    • If its not connected too tightly the crimps can be removed by hand pressure only.
    • If its too tight to be removed by hand, then you can use a pair of pliers to removed the crimps.
    • Never remove by pulling on the cables. Always pull by the metal crimps.
  4. Sony SS-CCP1 Speaker Replacement: passo 4, imagem 1 %32 Sony SS-CCP1 Speaker Replacement: passo 4, imagem 2 %32 Sony SS-CCP1 Speaker Replacement: passo 4, imagem 3 %32
    • Remove the crimps from the 12cm loudspeaker.
  5. Sony SS-CCP1 Speaker Replacement: passo 5, imagem 1 %32 Sony SS-CCP1 Speaker Replacement: passo 5, imagem 2 %32
    • Remove the grommet using an object with a flat edge.
    • The grommet is not made of rubber, it is made of plastic. Be careful when removing it, as it can break easily.
  6. Sony SS-CCP1 Speaker Replacement: passo 6, imagem 1 %32 Sony SS-CCP1 Speaker Replacement: passo 6, imagem 2 %32
    • Feed the speaker cable through the front of the box.
Conclusão
4 outras pessoas executaram este guia.
Dallas
Membro desde: 10/10/16
892 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-2, Baechle Fall 2016 Membro de IUPUI, Team 3-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 33
Duração total: 3,914
