Ir para o conteúdo principal
Sony SRS-XE200 Motherboard Replacement
O que você precisa
  1. Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: passo 1, imagem 1 %32 Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: passo 1, imagem 2 %32
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Motherboard Replacement: passo 2, imagem 1 %32
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Motherboard Replacement: passo 3, imagem 1 %32 Sony SRS-XE200 Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Motherboard Replacement: passo 4, imagem 1 %32 Sony SRS-XE200 Motherboard Replacement: passo 4, imagem 2 %32
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Sony SRS-XE200 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Sony SRS-XE200 Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the cord connecting the charging port to the motherboard.
  7. Sony SRS-XE200 Motherboard Replacement: passo 7, imagem 1 %32 Sony SRS-XE200 Motherboard Replacement: passo 7, imagem 2 %32 Sony SRS-XE200 Motherboard Replacement: passo 7, imagem 3 %32
    • Remove the two 0.8 mm screws attaching the motherboard to the case compartment with a Phillips #1 screwdriver.
    • Detach the motherboard from the case compartment.
Conclusão
Um comentário
Hy please I m from morrocco i need a matherbeard a have a speaker but not work i d'not no way i need help plz
Abdou Abdou - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 344
