Ir para o conteúdo principal
Sony SRS-XE200 Microphone Replacement
O que você precisa
  1. Sony SRS-XE200 Microphone Replacement, Speaker Assembly: passo 1, imagem 1 %32 Sony SRS-XE200 Microphone Replacement, Speaker Assembly: passo 1, imagem 2 %32
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Microphone Replacement: passo 2, imagem 1 %32
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Microphone Replacement: passo 3, imagem 1 %32 Sony SRS-XE200 Microphone Replacement: passo 3, imagem 2 %32
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Microphone Replacement: passo 4, imagem 1 %32 Sony SRS-XE200 Microphone Replacement: passo 4, imagem 2 %32
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Microphone Replacement, Battery: passo 5, imagem 1 %32 Sony SRS-XE200 Microphone Replacement, Battery: passo 5, imagem 2 %32 Sony SRS-XE200 Microphone Replacement, Battery: passo 5, imagem 3 %32
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Microphone Replacement: passo 6, imagem 1 %32 Sony SRS-XE200 Microphone Replacement: passo 6, imagem 2 %32 Sony SRS-XE200 Microphone Replacement: passo 6, imagem 3 %32
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Microphone Replacement, Charging Port: passo 7, imagem 1 %32 Sony SRS-XE200 Microphone Replacement, Charging Port: passo 7, imagem 2 %32
    • Remove the charging port.
  8. Sony SRS-XE200 Microphone Replacement, Microphone: passo 8, imagem 1 %32 Sony SRS-XE200 Microphone Replacement, Microphone: passo 8, imagem 2 %32 Sony SRS-XE200 Microphone Replacement, Microphone: passo 8, imagem 3 %32
    • Remove the two 0.8 mm screws connecting the motherboard to the microphone with a Phillips #1 screwdriver.
    • Remove the microphone.
  9. Sony SRS-XE200 Microphone Replacement: passo 9, imagem 1 %32
  10. Sony SRS-XE200 Microphone Replacement: passo 10, imagem 1 %32 Sony SRS-XE200 Microphone Replacement: passo 10, imagem 2 %32
  11. Sony SRS-XE200 Microphone Replacement: passo 11, imagem 1 %32 Sony SRS-XE200 Microphone Replacement: passo 11, imagem 2 %32 Sony SRS-XE200 Microphone Replacement: passo 11, imagem 3 %32
    • Remove the microphone from the case of the speaker.
    • Replace the microphone.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 302
