Ir para o conteúdo principal
Sony SRS-XE200 Battery Replacement
O que você precisa
  1. Sony SRS-XE200 Battery Replacement, Speaker Assembly: passo 1, imagem 1 %32 Sony SRS-XE200 Battery Replacement, Speaker Assembly: passo 1, imagem 2 %32
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Battery Replacement: passo 2, imagem 1 %32
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Battery Replacement: passo 3, imagem 1 %32 Sony SRS-XE200 Battery Replacement: passo 3, imagem 2 %32
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Battery Replacement: passo 4, imagem 1 %32 Sony SRS-XE200 Battery Replacement: passo 4, imagem 2 %32
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Battery Replacement, Battery: passo 5, imagem 1 %32 Sony SRS-XE200 Battery Replacement, Battery: passo 5, imagem 2 %32 Sony SRS-XE200 Battery Replacement, Battery: passo 5, imagem 3 %32
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Battery Replacement: passo 6, imagem 1 %32 Sony SRS-XE200 Battery Replacement: passo 6, imagem 2 %32 Sony SRS-XE200 Battery Replacement: passo 6, imagem 3 %32
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
Thanks what is the replacement battery number?
fred Pope - Responder
What is the battery number for the SRS replacement
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 54
Duração total: 680
