Introdução
In this guide, you will be removing and replacing a faulty LED control panel located on the back of the speaker plate. If your LED lights aren't working on your SONY SRS-XB40 speaker, then more than likely the control panel is at fault.
O que você precisa
Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
After you take the speaker plate off the body of the speaker, locate the LED control panels on each end of the speaker plate.
