Introdução
In order to replace the auxiliary input port, you will need to follow the prerequisite guide to get to the internal part of the speaker and remove it from the speaker structure. This guide is moderately difficult and you must complete the steps in order to get the piece you need to replace.
O que você precisa
Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
Unscrew the PH 1 (10 mm) screws from the black outer casing of the auxiliary port.
5 comentários
Yea but where do I buy the aux input? You say one new part. They don’t offer it on the Sony parts supplier website. https://sony.encompass.com/model/SONSRSX...
Where can i find the part to repair it?
I am trying to find the auxiliary port, I can’t find it anywhere right now.
Did you find one? If so where please?
Where can I source the aux in part? This is the same question as the last 3 comments! Have I missed something?
