O que você precisa
To remove the speaker grill, insert the big spudger underneath it in each corner.
Locate the four screws on the now exposed front panel.
Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
Locate two silver screws (9mm) attached to each speaker shield.
Remove the two silver screws on each speaker shield using the screwdriver with the PH1 head.
3 outras pessoas executaram este guia.
2 comentários
Are there any replacement drivers for this or the XB31?
