Ir para o conteúdo principal
Sony SRS-XB30 Charging Port Replacement
O que você precisa
  1. Sony SRS-XB30 Charging Port Replacement, Battery: passo 1, imagem 1 %32
    • To remove the speaker grill, insert the big spudger underneath it in each corner.
    • Work around the edges to pry the grill up and off.
  2. Sony SRS-XB30 Charging Port Replacement: passo 2, imagem 1 %32 Sony SRS-XB30 Charging Port Replacement: passo 2, imagem 2 %32
    • With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
    • This will need to be done on all four sides of the speaker to remove all four panels
    • This requires some effort because the adhesive is sticky.
  3. Sony SRS-XB30 Charging Port Replacement: passo 3, imagem 1 %32 Sony SRS-XB30 Charging Port Replacement: passo 3, imagem 2 %32
    • Locate the four screws on the now exposed front panel.
    • Using the screwdriver with bit T7, unscrew each screw (15.0 mm long).
    In my speakers it was T8 size
    Filipe Silva - Responder
  4. Sony SRS-XB30 Charging Port Replacement: passo 4, imagem 1 %32
    • Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
    • Use the same T7 screwdriver head here.
    • Remove each of the four corner screws (15.0 mm long).
  5. Sony SRS-XB30 Charging Port Replacement: passo 5, imagem 1 %32
    • With a little force, carefully lift the lid of the speaker.
    • Make sure that you do not pull on the wires.
  6. Sony SRS-XB30 Charging Port Replacement: passo 6, imagem 1 %32 Sony SRS-XB30 Charging Port Replacement: passo 6, imagem 2 %32 Sony SRS-XB30 Charging Port Replacement: passo 6, imagem 3 %32
    • Unclip the four wire connectors (that are attached to the speaker lid).
    • Disconnect the thin yellow wire (attached to the speaker lid) from its port.
  7. Sony SRS-XB30 Charging Port Replacement: passo 7, imagem 1 %32
    • Separate the speaker lid from the bottom frame.
    • To prepare the speaker for the next step place the lid parallel to the frame.
  8. Sony SRS-XB30 Charging Port Replacement: passo 8, imagem 1 %32
    • Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
    • Using the screwdriver with bit PH1, unscrew each screw.
  9. Sony SRS-XB30 Charging Port Replacement: passo 9, imagem 1 %32
    • Separate the speaker lid entirely from the bottom frame.
    You have to remove de NFC circuit before the next step, or you wil broke the connection .
    Jaja - Responder
  10. Sony SRS-XB30 Charging Port Replacement: passo 10, imagem 1 %32
    • Remove the top screw (10 mm).
    • Use the screwdriver with bit T7.
  11. Sony SRS-XB30 Charging Port Replacement: passo 11, imagem 1 %32 Sony SRS-XB30 Charging Port Replacement: passo 11, imagem 2 %32
    • Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
    • There are two screws on the left side of the white box and one to its right.
    What is the power circuit board name? Where it found?
    hiftekhar16 - Responder
  12. Sony SRS-XB30 Charging Port Replacement: passo 12, imagem 1 %32
    • Slightly lift the white box with all the wires still attached.
  13. Sony SRS-XB30 Charging Port Replacement: passo 13, imagem 1 %32 Sony SRS-XB30 Charging Port Replacement: passo 13, imagem 2 %32
    • Take the big spudger and pry the black casing up from the circuit box.
  14. Sony SRS-XB30 Charging Port Replacement: passo 14, imagem 1 %32
    • Locate the blue film attached to the circuit box containing the charging port.
    • Detach the blue film from the box.
  15. Sony SRS-XB30 Charging Port Replacement: passo 15, imagem 1 %32
    • Detach the yellow, black and red wires by pulling them directly up.
  16. Sony SRS-XB30 Charging Port Replacement: passo 16, imagem 1 %32 Sony SRS-XB30 Charging Port Replacement: passo 16, imagem 2 %32
    • Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
  17. Sony SRS-XB30 Charging Port Replacement, Charging Port: passo 17, imagem 1 %32
    • Locate the circuit box containing the yellow charging port.
    • Remove the circuit box from any attachments connecting it to the speaker.
    I have just received a new battery and fitted it but still does not turn on , am not able to find a replacement charging port even from Sony any help please
    Philip Bracken - Responder
  18. Sony SRS-XB30 Charging Port Replacement: passo 18, imagem 1 %32
    • Insert a new circuit box.
    Wherre can i order a new circuit bord
    Daan Vulpen - Responder
    please give me full circuit pcb board clear view of crarging port ,
    K Kabir - Responder
    Donde lo puedo compar?
    Luis Velez - Responder
Conclusão
4 outras pessoas executaram este guia.
8 comentários
Hi where I can find new circuit box?
cesar2_realmadrid - Responder
YEAH - WERE DO YOU GET A REPLACEMENT?
Cheers
Tim
Tim Terry - Responder
That’s right , at the very beginning it says that no parts are needed , what about the new charging port where can we get it?
Julio aguilar 44 - Responder
I am incredibly curious, and a little bit excited, to hear what it is that was going through your mind at the start of this in comparison to when you reached the end? The exact moment that the very title of this article says very clearly the word “replacement” and then to see the amazing luck of the mistaken omission which read “No Parts Required” only to then be let down again when you realized that a part was in fact required. After-all it is called “Charging Port Replacement” so I’m sure you probably healed up pretty quick from the heartbreak you suffered.
John Wick -
Very clear instructions, thanks.
Any idea where I can find a new charging port for my speaker? Can’t find anything on the internet..
Thanks by advance
Dries
driesdebrauwer123 - Responder
I actually used this guide to install a type C charging port to the speaker. I bought a microusb to type C female cable, soldered the ground and 5v in parallel to the charging port and put it in place of the USB port.
Seanwee -
Removal of NFC board is missing. It should be detouched from the glue and pulled out carefully. it has a small socket with 4 pins underneath. I broke mine.
Igor Goncharov - Responder
Nesecito una parte
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 29
Últimos 30 dias: 115
Duração total: 13,105
