Introdução
One of the common problems with the Sony SRS-XB30 is trouble syncing with the Bluetooth chip. This guide will give you step by step instructions on how to replace the Bluetooth chip.
O que você precisa
To remove the speaker grill, insert the big spudger underneath it in each corner.
Locate the four screws on the now exposed front panel.
Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
3 outras pessoas executaram este guia.
