Ir para o conteúdo principal
Sony SRS-XB30 Battery Replacement
O que você precisa
  1. Sony SRS-XB30 Battery Replacement, Battery: passo 1, imagem 1 %32
    • To remove the speaker grill, insert the big spudger underneath it in each corner.
    • Work around the edges to pry the grill up and off.
  2. Sony SRS-XB30 Battery Replacement: passo 2, imagem 1 %32 Sony SRS-XB30 Battery Replacement: passo 2, imagem 2 %32
    • With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
    • This will need to be done on all four sides of the speaker to remove all four panels
    • This requires some effort because the adhesive is sticky.
  3. Sony SRS-XB30 Battery Replacement: passo 3, imagem 1 %32 Sony SRS-XB30 Battery Replacement: passo 3, imagem 2 %32
    • Locate the four screws on the now exposed front panel.
    • Using the screwdriver with bit T7, unscrew each screw (15.0 mm long).
    In my speakers it was T8 size
    Filipe Silva - Responder
  4. Sony SRS-XB30 Battery Replacement: passo 4, imagem 1 %32
    • Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
    • Use the same T7 screwdriver head here.
    • Remove each of the four corner screws (15.0 mm long).
  5. Sony SRS-XB30 Battery Replacement: passo 5, imagem 1 %32
    • With a little force, carefully lift the lid of the speaker.
    • Make sure that you do not pull on the wires.
  6. Sony SRS-XB30 Battery Replacement: passo 6, imagem 1 %32 Sony SRS-XB30 Battery Replacement: passo 6, imagem 2 %32 Sony SRS-XB30 Battery Replacement: passo 6, imagem 3 %32
    • Unclip the four wire connectors (that are attached to the speaker lid).
    • Disconnect the thin yellow wire (attached to the speaker lid) from its port.
  7. Sony SRS-XB30 Battery Replacement: passo 7, imagem 1 %32
    • Separate the speaker lid from the bottom frame.
    • To prepare the speaker for the next step place the lid parallel to the frame.
  8. Sony SRS-XB30 Battery Replacement: passo 8, imagem 1 %32
    • Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
    • Using the screwdriver with bit PH1, unscrew each screw.
  9. Sony SRS-XB30 Battery Replacement: passo 9, imagem 1 %32
    • Separate the speaker lid entirely from the bottom frame.
    You have to remove de NFC circuit before the next step, or you wil broke the connection .
    Jaja - Responder
  10. Sony SRS-XB30 Battery Replacement: passo 10, imagem 1 %32
    • Remove the top screw (10 mm).
    • Use the screwdriver with bit T7.
  11. Sony SRS-XB30 Battery Replacement: passo 11, imagem 1 %32 Sony SRS-XB30 Battery Replacement: passo 11, imagem 2 %32
    • Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
    • There are two screws on the left side of the white box and one to its right.
    What is the power circuit board name? Where it found?
    hiftekhar16 - Responder
  12. Sony SRS-XB30 Battery Replacement: passo 12, imagem 1 %32
    • Slightly lift the white box with all the wires still attached.
  13. Sony SRS-XB30 Battery Replacement: passo 13, imagem 1 %32 Sony SRS-XB30 Battery Replacement: passo 13, imagem 2 %32
    • Take the big spudger and pry the black casing up from the circuit box.
  14. Sony SRS-XB30 Battery Replacement: passo 14, imagem 1 %32
    • Locate the blue film attached to the circuit box containing the charging port.
    • Detach the blue film from the box.
  15. Sony SRS-XB30 Battery Replacement: passo 15, imagem 1 %32
    • Detach the yellow, black and red wires by pulling them directly up.
  16. Sony SRS-XB30 Battery Replacement: passo 16, imagem 1 %32 Sony SRS-XB30 Battery Replacement: passo 16, imagem 2 %32
    • Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
Conclusão
24 outras pessoas executaram este guia.
8 comentários
Hello. Would you upload a detailed photo of the motherboard and the built-in amplifier? I’d like to know if I could find the right IC which I want to change. Thank you! and great guide!
Santiago Gómez - Responder
Can you help with what kind of battery I need? I would like to purchase it before I take everything apart. Thank you.
Betty Stewart - Responder
I really like the sound of this BT device. That´s why I own one of these. I just want to know how to convert this rechargeable speaker into AC power supply device because I don´t want to buy a battery replacement when the original one runs out. I don´t know how to calculate the volts and amperes needed to supply this speaker.
Max Bonett - Responder
Which adhesive should be bought to put it all back together? Are there parts which can break or go in unoriginal form and should be romoved or fixed back together carefully? Also the link for the battery on amazon which is posted cant supply right now: is there any alternatives?
Thank you for making this guide and helping out :D
Unhappywithunrepairibility - Responder
Which adhesive should be bought to put it all back together? Are there parts which can break or go in unoriginal form and should be removed or fixed back together carefully? Also is there any alternatives to were the battery can be bought?
Beware NFC chip on the top panel (under the ADD button). It should stay blued on the top shell when you separate you. Be gentle with the top shell while doing step 2.
If the chip stayed on the speaker, you beed a way to gently separate it. Without separating it, you simply break NFC connection.
Aliaksei Belski - Responder
This is good information however, without a source where to obtain a replacement new battery for Sony's SRS-XB43 it is moot
Doubletap - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 52
Últimos 30 dias: 202
Duração total: 25,299
