Introdução
If you notice that the microphone in your speaker has stopped working, this guide will show you the steps to take to reach the microphone and remove it for replacement. The majority of repair time will be spent attempting to open the device, as it is sealed shut by adhesive. Once open, the repair is straightforward.
Keep in mind that opening the speaker will nullify the IP67 (waterproof and dustproof) rating, and may cause slight external damage when attempting to open.
O que você precisa
To get the bottom part of the speaker off, take a long and sturdy screwdriver and put it through the holes at the bottom of the speaker.
When you have the screwdriver through the holes, you'll want to push down very firmly. Rotate between the holes and repeat this process until the bottom piece pops off.
To unplug the microphone from the motherboard, use the nylon tipped tweezers to clamp the white block that is attached to the red and white wires.
Pull up and away from the motherboard until the block is fully disconnected from the slot.
