Introdução
This guide demonstrates how to replace the USB/AUX board.
O que você precisa
To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
Unplug the cord connected to the motherboard by squeezing the plastic sides.
Using the Phillips #1 screwdriver, remove the two 6mm screws holding the AUX board in place.
Uma outra pessoa concluiu este guia.
2 comentários
hi there, where can i buy aux board for replacement? thank you
Donde puedo conseguir la tarjeta?
