Ir para o conteúdo principal
Sony SRS-X5 Button Pad Replacement
O que você precisa
  1. Sony SRS-X5 Button Pad Replacement, Battery: passo 1, imagem 1 %32
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 Button Pad Replacement: passo 2, imagem 1 %32 Sony SRS-X5 Button Pad Replacement: passo 2, imagem 2 %32
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Button Pad Replacement: passo 3, imagem 1 %32
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Button Pad Replacement, Speaker: passo 4, imagem 1 %32
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 Button Pad Replacement: passo 5, imagem 1 %32
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Button Pad Replacement: passo 6, imagem 1 %32 Sony SRS-X5 Button Pad Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Button Pad Replacement: passo 7, imagem 1 %32 Sony SRS-X5 Button Pad Replacement: passo 7, imagem 2 %32 Sony SRS-X5 Button Pad Replacement: passo 7, imagem 3 %32
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
  8. Sony SRS-X5 Button Pad Replacement, Button Pad: passo 8, imagem 1 %32
    • Unplug the electrical cord from the button pad.
  9. Sony SRS-X5 Button Pad Replacement: passo 9, imagem 1 %32 Sony SRS-X5 Button Pad Replacement: passo 9, imagem 2 %32
    • Using both the plastic opening tool and metal spudger gently pry open the cover from the top of the speaker.
  10. Sony SRS-X5 Button Pad Replacement: passo 10, imagem 1 %32
    • Gently remove the cover using your hands.
    • Make sure you remove the cover gently so it doesn't break.
  11. Sony SRS-X5 Button Pad Replacement: passo 11, imagem 1 %32 Sony SRS-X5 Button Pad Replacement: passo 11, imagem 2 %32
    • Using the Phillips #00, unscrew the three 3.32mm screws keeping the button board in place.
  12. Sony SRS-X5 Button Pad Replacement: passo 12, imagem 1 %32
    • Gently remove the button pad from the speaker.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,059
