Ir para o conteúdo principal
Sony SRS-X3 Battery Replacement
O que você precisa
  1. Sony SRS-X3 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the 6 philips head screws using the PH1 bit.
  2. Sony SRS-X3 Battery Replacement: passo 2, imagem 1 %32
    • Remove the 3 philips head screws holding in the green circuit board
  3. Sony SRS-X3 Battery Replacement: passo 3, imagem 1 %32
    • Unclip the battery pack and replace it with another one.
Conclusão
6 outras pessoas executaram este guia.
3 comentários
Can you give the battery # on this please
Dan Clark - Responder
Good instructions. I had one problem when removing the green circuit card. The ribbon cable came out. On mine there was a small black retention bar that I flipped open to allow the ribbon cable to reinsert, then I returned the retention bar back down to secure the ribbon cable in place. It worked fine after that.
Harpo - Responder
It would be nice if the article addressed the 6 rubber pads that cover the screws. There doesn't seem to be a way to remove them without damaging them, and you need them in order to use the speaker without it rattling and moving about from vibrations.
Peter Nosko - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 21
Últimos 30 dias: 117
Duração total: 6,985
