Ir para o conteúdo principal
Sony SRS-X3 Battery Charging Port Replacement
O que você precisa
  1. Sony SRS-X3 Battery Charging Port Replacement, Battery Charging Port: passo 1, imagem 1 %32
    • Remove the 6 10mm Philips head screws shown, using a PH1 screwdriver
  2. Sony SRS-X3 Battery Charging Port Replacement: passo 2, imagem 1 %32
    • Remove the 5 8mm Philips head screws shown. These are holding the battery and the green circuit board in.
  3. Sony SRS-X3 Battery Charging Port Replacement: passo 3, imagem 1 %32
    • Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
  4. Sony SRS-X3 Battery Charging Port Replacement: passo 4, imagem 1 %32 Sony SRS-X3 Battery Charging Port Replacement: passo 4, imagem 2 %32
    • Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
    • After the connections are remove you are free to replace the circuit board.
Conclusão
5 outras pessoas executaram este guia.
11 comentários
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
michael ruse - Responder
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
Julie Miller -
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
kennycontreras44 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 29
Duração total: 6,663
