Ir para o conteúdo principal
Sony SLT Alpha-65V Viewfinder Replacement
O que você precisa
  1. Sony SLT Alpha-65V Viewfinder Replacement, Back Panel: passo 1, imagem 1 %32
    • Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
    • Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
  2. Sony SLT Alpha-65V Viewfinder Replacement: passo 2, imagem 1 %32
    • Unscrew the 4.0 mm Phillips #00 screw on bottom of the left side of the camera.
    • Unscrew the 5.0 mm Phillips #00 screw near the top of the left side of the camera.
  3. Sony SLT Alpha-65V Viewfinder Replacement: passo 3, imagem 1 %32
    • Be careful when pulling the back panel away as it will still be connected to the body of the camera by two strips of film.
    • When unscrewing the 5.0 mm screw on the dial, make sure to hold onto the dial that becomes detached after taking out the screw.
    • Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
    • Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
    • Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
  4. Sony SLT Alpha-65V Viewfinder Replacement: passo 4, imagem 1 %32 Sony SLT Alpha-65V Viewfinder Replacement: passo 4, imagem 2 %32 Sony SLT Alpha-65V Viewfinder Replacement: passo 4, imagem 3 %32
    • Remove the two 4.0 mm Phillips #00 screws on the right of the camera that are located on the upper right side and under the "Remote" port flap.
    • Detach the right side panel with the remote and HDMI ports of the camera by gently pulling on the panel.
  5. Sony SLT Alpha-65V Viewfinder Replacement: passo 5, imagem 1 %32
    • When the back panel is removed, be careful when moving the camera. There are parts inside the camera which now may come loose.
    • Use tweezers to remove the blue and orange ribbon connectors from their connection points pictured here.
  6. Sony SLT Alpha-65V Viewfinder Replacement, Motherboard: passo 6, imagem 1 %32
    • Remove the four 3.0 mm Phillips #00 screws.
    • Remove the 5.0 mm Phillips #00 screw.
  7. Sony SLT Alpha-65V Viewfinder Replacement: passo 7, imagem 1 %32 Sony SLT Alpha-65V Viewfinder Replacement: passo 7, imagem 2 %32 Sony SLT Alpha-65V Viewfinder Replacement: passo 7, imagem 3 %32
    • Don't forget to close these switches and lock the film back into place when reassembling the camera.
    • Use your finger to flip the switch that holds the dual ribbon connector in place.
    • Gently use tweezers to disconnect the dual ribbon connector and the thin blue ribbon connector to the right of it from the circuit board.
  8. Sony SLT Alpha-65V Viewfinder Replacement: passo 8, imagem 1 %32 Sony SLT Alpha-65V Viewfinder Replacement: passo 8, imagem 2 %32 Sony SLT Alpha-65V Viewfinder Replacement: passo 8, imagem 3 %32
    • Use tweezers to disconnect the blue, gold, and brown ribbon connectors near the top of the camera.
  9. Sony SLT Alpha-65V Viewfinder Replacement: passo 9, imagem 1 %32 Sony SLT Alpha-65V Viewfinder Replacement: passo 9, imagem 2 %32
    • Use a plastic opening tool to pop open the connector holding the next ribbon to the circuit board.
    • Use tweezers to disconnect the ribbon.
  10. Sony SLT Alpha-65V Viewfinder Replacement: passo 10, imagem 1 %32
    • Use tweezers to unplug the blue adapter located at the top right of the circuit board.
  11. Sony SLT Alpha-65V Viewfinder Replacement: passo 11, imagem 1 %32
    • Use either plastic opening tools or tweezers to unplug the white adapter located on the right side of the circuit board.
  12. Sony SLT Alpha-65V Viewfinder Replacement: passo 12, imagem 1 %32
    • The circuit board will still be connected to the body of the camera by two pairs of cords.
    • Gently lift the circuit board away from the camera and turn it over.
    • Use tweezers to disconnect the final two plugs and completely remove the circuit board from the camera.
  13. Sony SLT Alpha-65V Viewfinder Replacement, Viewfinder: passo 13, imagem 1 %32 Sony SLT Alpha-65V Viewfinder Replacement, Viewfinder: passo 13, imagem 2 %32 Sony SLT Alpha-65V Viewfinder Replacement, Viewfinder: passo 13, imagem 3 %32
    • The rotating dial on the right side of the eyepiece sensor is loosely connected and may fall out when removing the sensor.
    • Gently remove the eyepiece sensor from the viewfinder.
  14. Sony SLT Alpha-65V Viewfinder Replacement: passo 14, imagem 1 %32 Sony SLT Alpha-65V Viewfinder Replacement: passo 14, imagem 2 %32
    • The viewfinder will pop out of its slot.
    • Gently remove the viewfinder from the camera.
Conclusão
Zhengjun Jiang
Membro desde: 04/28/15
140 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-11, Amido Spring 2015 Membro de Cal Poly, Team 14-11, Amido Spring 2015
CPSU-AMIDO-S15S14G11
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,320
