Introdução
This guide will show you how to unscrew the LCD screen housing from the back of the camera and disconnect the screen's circuitry from the circuitry of the rest of the camera. This requires using a Phillips #00 screwdriver and a plastic opening tool to remove the screen. It is very helpful to use a magnetic pad to organize and keep track of all the screws removed from the camera.
O que você precisa
Remove the two 4.0 mm Phillips #00 screws on the base of the camera.
Remove the 3.0 mm Phillips #00 screw on the hinge of the screen.
7 outras pessoas executaram este guia.
3 comentários
my father used to repair black and white tv in the 80's here in the country of PERU, so I thought, my father repairs tv I must have inherited the skill so I will repair my a77v camera, result = I messed up more xD.
At the moment the screen did not emit an image, it went all black, when I uncovered the screen I found a pcb which was missing a component, I started cleaning with a toothbrush and 2 more components came off, I could not identify if they are resistors, capacitors or diodes, I looked for the schematic on the web but I didn't find anything related, could you help me identify which components are missing? Is there a way to upload an image here to show where they came off? I will be very grateful, ATTE: a friend from Peru.
Thanks for the Tutorial, I miss however the Part Number for a new disolay and maybe a source where to buy.
Regards
Willie
