Ir para o conteúdo principal
Sony RDR HX750 HX950 Disassembly
O que você precisa
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: passo 1, imagem 1 %32 Sony RDR HX750 HX950 Disassembly, Remove cover: passo 1, imagem 2 %32 Sony RDR HX750 HX950 Disassembly, Remove cover: passo 1, imagem 3 %32
    • Remove the screws from the back and sides of the top cover.
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: passo 2, imagem 1 %32 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: passo 2, imagem 2 %32 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: passo 2, imagem 3 %32
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: passo 3, imagem 1 %32 Sony RDR HX750 HX950 Disassembly, Remove DVD player: passo 3, imagem 2 %32 Sony RDR HX750 HX950 Disassembly, Remove DVD player: passo 3, imagem 3 %32
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: passo 4, imagem 1 %32 Sony RDR HX750 HX950 Disassembly, Remove front Panel: passo 4, imagem 2 %32 Sony RDR HX750 HX950 Disassembly, Remove front Panel: passo 4, imagem 3 %32
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: passo 5, imagem 1 %32 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: passo 5, imagem 2 %32 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: passo 5, imagem 3 %32
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: passo 6, imagem 1 %32 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: passo 6, imagem 2 %32 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: passo 6, imagem 3 %32
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: passo 7, imagem 1 %32 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: passo 7, imagem 2 %32 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: passo 7, imagem 3 %32
    • Inserir instruções aqui.
Conclusão
To open this dvd recorder folow this tutorial
Cafony
Membro desde: 02/17/15
687 Reputação
Autoria de 4 guias
Um comentário
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 58
Duração total: 5,410
