Introdução
This guide will show how to remove the hard drive and the optical drive for the Sony RDR HX.
Ferramentas
Peças
Nenhum componente especificado.
Remove the screws that old hard drive
Unplug the cables from disk
Remove screws from back side of hard drive
Remove Screws from dvd cover
Remove screws from plastic cable holder
Inser litle paper under each "click" to remove front panel.
When each "click" is lose, puch front panel gently, it will go out easily.
The table of compac disk has a little plastic in front that goes out "up" with a "click"
Unplug the cables show on foto.
Desconect this cable hided on the side.
Remove the little piece on cd reader, It has a click.
Under the dvd block remove screws
Then remove screws on board
Now you can access the laser
To open this dvd recorder folow this tutorial
