Ir para o conteúdo principal
Sony Pulse Elite Edition Headband Replacement
O que você precisa
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: passo 1, imagem 1 %32 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: passo 1, imagem 2 %32
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: passo 2, imagem 1 %32 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: passo 2, imagem 2 %32
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: passo 3, imagem 1 %32 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: passo 3, imagem 2 %32 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: passo 3, imagem 3 %32
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: passo 4, imagem 1 %32
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
Conclusão
3 outras pessoas executaram este guia.
Chris Echter
Membro desde: 01/29/15
865 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 14-2, Shirley Spring 2015 Membro de Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
Membros da 5
Autoria de 12 guias
Um comentário
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 104
Duração total: 6,098
