Ir para o conteúdo principal
Sony PlayStation Camera Microphone Array Replacement
O que você precisa
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: passo 1, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: passo 1, imagem 2 %32
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
  2. Sony PlayStation Camera Microphone Array Replacement: passo 2, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 2, imagem 2 %32
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
  3. Sony PlayStation Camera Microphone Array Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the cap holding the cable grommet in place.
  4. Sony PlayStation Camera Microphone Array Replacement: passo 4, imagem 1 %32
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
  5. Sony PlayStation Camera Microphone Array Replacement: passo 5, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 5, imagem 2 %32
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
  6. Sony PlayStation Camera Microphone Array Replacement: passo 6, imagem 1 %32
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
  7. Sony PlayStation Camera Microphone Array Replacement: passo 7, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 7, imagem 2 %32
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
  8. Sony PlayStation Camera Microphone Array Replacement: passo 8, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 8, imagem 2 %32 Sony PlayStation Camera Microphone Array Replacement: passo 8, imagem 3 %32
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
  9. Sony PlayStation Camera Microphone Array Replacement: passo 9, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 9, imagem 2 %32
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
  10. Sony PlayStation Camera Microphone Array Replacement: passo 10, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 10, imagem 2 %32
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
  11. Sony PlayStation Camera Microphone Array Replacement: passo 11, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 11, imagem 2 %32 Sony PlayStation Camera Microphone Array Replacement: passo 11, imagem 3 %32
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
Conclusão
Uma outra pessoa concluiu este guia.
Joshua Gates
Membro desde: 02/15/17
268 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-5, Passmore Spring 2017 Membro de USF Tampa, Team 5-5, Passmore Spring 2017
USFT-PASSMORE-S17S5G5
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 92
Ao todo: 7,673
