Introdução
Released November 13, 2011, this is the only model ever released. It can be disassembled with screwdrivers and a small amount of prying. Model # CECH-ZED1U
O que você precisa
With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
3 outras pessoas executaram este guia.
Um comentário
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
Como se consigue la base de unidad sola??
no encuentro en ninguna parte, de casualidad tu sabras?
DYLAN DGUEZ - Responder
