Ir para o conteúdo principal
Sony PlayStation 3D Display Indicator Light Bar Replacement
O que você precisa
  1. Sony PlayStation 3D Display Indicator Light Bar Replacement, Rear Case: passo 1, imagem 1 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 2, imagem 1 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 2, imagem 2 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 2, imagem 3 %32
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 3, imagem 1 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 3, imagem 2 %32
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 4, imagem 1 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 4, imagem 2 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 4, imagem 3 %32
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Indicator Light Bar Replacement, Indicator Light Bar: passo 5, imagem 1 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement, Indicator Light Bar: passo 5, imagem 2 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement, Indicator Light Bar: passo 5, imagem 3 %32
    • With the Phillips #02 screwdriver, remove the two 5mm length x 5mm head screws located on the left and right side of the light bar board.
  6. Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 6, imagem 1 %32 Sony PlayStation 3D Display Indicator Light Bar Replacement: passo 6, imagem 2 %32
    • Remove the light bar by depressing the tab on the white data connector.
Conclusão
Uma outra pessoa concluiu este guia.
Kyle Franck
Membro desde: 10/01/15
233 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-16, Maness Fall 2015 Membro de Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Membros
8 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 494
