Ir para o conteúdo principal
Sony PS1100 Needle Cartridge Replacement
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: passo 1, imagem 1 %32 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: passo 1, imagem 2 %32 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: passo 1, imagem 3 %32
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: passo 2, imagem 1 %32
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: passo 3, imagem 1 %32 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: passo 3, imagem 2 %32
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: passo 4, imagem 1 %32
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
Conclusão
Uma outra pessoa concluiu este guia.
L Cis
Membro desde: 10/10/14
110 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-8, Donnelly Fall 2014 Membro de USF Tampa, Team 1-8, Donnelly Fall 2014
USFT-DONNELLY-F14S1G8
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 30
Duração total: 4,613
