Ir para o conteúdo principal
Sony PS-LX300USB Dust Cover Replacement
O que você precisa
  1. Sony PS-LX300USB Dust Cover Replacement, Dust Cover: passo 1, imagem 1 %32
    • Turn the turntable around so that the back side is visible.
  2. Sony PS-LX300USB Dust Cover Replacement: passo 2, imagem 1 %32 Sony PS-LX300USB Dust Cover Replacement: passo 2, imagem 2 %32
    • Begin by releasing the left latch. Apply downward pressure to the square, black button using a flathead screw driver.
    • Once the latch is released, lift upward.
    • Use your left hand to hold the left side of the dust cover above the latch. This ensures the latch does not reconnect.
  3. Sony PS-LX300USB Dust Cover Replacement: passo 3, imagem 1 %32
    • Use a flat head screw driver to apply pressure to the black square button on the right side.
  4. Sony PS-LX300USB Dust Cover Replacement: passo 4, imagem 1 %32 Sony PS-LX300USB Dust Cover Replacement: passo 4, imagem 2 %32
    • Once both the right and left buttons are released, pull the dust cover upwards.
    • The dust cover is now disconnected and ready for replacement.
Conclusão
Sean
Membro desde: 09/27/17
109 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S8-G3, Banghart Fall 2017 Membro de Cal Poly, Team S8-G3, Banghart Fall 2017
CPSU-BANGHART-F17S8G3
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 19
Duração total: 2,303
