Ir para o conteúdo principal
Sony NWZ-E473 Front Button Replacement
O que você precisa
  1. Sony NWZ-E473 Front Button Replacement, Back Panel: passo 1, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Front Button Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Front Button Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Front Button Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Front Button Replacement: passo 5, imagem 1 %32 Sony NWZ-E473 Front Button Replacement: passo 5, imagem 2 %32 Sony NWZ-E473 Front Button Replacement: passo 5, imagem 3 %32
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Front Button Replacement, Battery: passo 6, imagem 1 %32 Sony NWZ-E473 Front Button Replacement, Battery: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Front Button Replacement: passo 7, imagem 1 %32 Sony NWZ-E473 Front Button Replacement: passo 7, imagem 2 %32
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Front Button Replacement: passo 8, imagem 1 %32
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Front Button Replacement: passo 9, imagem 1 %32
    • Use a soldering iron to remove the wires from the red and the black terminals.
  10. Sony NWZ-E473 Front Button Replacement, Screen: passo 10, imagem 1 %32
    Comprar
    • Use a nylon spudger or tweezers to remove the plastic USB cover.
  11. Sony NWZ-E473 Front Button Replacement: passo 11, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws located on the top corners of the device.
  12. Sony NWZ-E473 Front Button Replacement: passo 12, imagem 1 %32
    • Use a nylon spudger or tweezers to remove the plastic protective plate at the top of device.
  13. Sony NWZ-E473 Front Button Replacement: passo 13, imagem 1 %32 Sony NWZ-E473 Front Button Replacement: passo 13, imagem 2 %32
    • Remove the plastic protective frame located over the motherboard with tweezers and a spudger.
  14. Sony NWZ-E473 Front Button Replacement: passo 14, imagem 1 %32
    • Remove screen connection from motherboard using tweezers and spudger.
  15. Sony NWZ-E473 Front Button Replacement: passo 15, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove two 3 mm screws at the bottom sides and two 1 mm screws at top sides of the device.
  16. Sony NWZ-E473 Front Button Replacement: passo 16, imagem 1 %32 Sony NWZ-E473 Front Button Replacement: passo 16, imagem 2 %32
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws, and remove the motherboard from the device with tweezers and a plastic opening tool.
  17. Sony NWZ-E473 Front Button Replacement: passo 17, imagem 1 %32 Sony NWZ-E473 Front Button Replacement: passo 17, imagem 2 %32
    • Disconnect the metal shielding plate from the front panel with tweezers or a plastic opening tool.
  18. Sony NWZ-E473 Front Button Replacement: passo 18, imagem 1 %32 Sony NWZ-E473 Front Button Replacement: passo 18, imagem 2 %32
    • Use a plastic opening tool to remove the screen from metal back plate.
  19. Sony NWZ-E473 Front Button Replacement, Front Button: passo 19, imagem 1 %32
    • Ensure that button connection is completely separated from the buttons.
  20. Sony NWZ-E473 Front Button Replacement: passo 20, imagem 1 %32 Sony NWZ-E473 Front Button Replacement: passo 20, imagem 2 %32 Sony NWZ-E473 Front Button Replacement: passo 20, imagem 3 %32
    • Remove buttons from front display panel by pushing button display from the front of the device
Conclusão
Matthew Hintz
Membro desde: 01/16/15
327 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 17-6, Watkins Winter 2015 Membro de USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 1,778
