Ir para o conteúdo principal
Sony NWZ-E473 Battery Replacement
O que você precisa
  1. Sony NWZ-E473 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Battery Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Battery Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Battery Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Battery Replacement: passo 5, imagem 1 %32 Sony NWZ-E473 Battery Replacement: passo 5, imagem 2 %32 Sony NWZ-E473 Battery Replacement: passo 5, imagem 3 %32
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Battery Replacement, Battery: passo 6, imagem 1 %32 Sony NWZ-E473 Battery Replacement, Battery: passo 6, imagem 2 %32
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Battery Replacement: passo 7, imagem 1 %32 Sony NWZ-E473 Battery Replacement: passo 7, imagem 2 %32
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Battery Replacement: passo 8, imagem 1 %32
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Battery Replacement: passo 9, imagem 1 %32
    • Use a soldering iron to remove the wires from the red and the black terminals.
Conclusão
4 outras pessoas executaram este guia.
Matthew Hintz
Membro desde: 01/16/15
327 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 17-6, Watkins Winter 2015 Membro de USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
Membros da 4
Autoria de 5 guias
2 comentários
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - Responder
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
guy lewit -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 37
Duração total: 9,507
