Ir para o conteúdo principal
Sony NEX-7 Battery Replacement
  1. Sony NEX-7 Battery Replacement, Battery: passo 1, imagem 1 %32 Sony NEX-7 Battery Replacement, Battery: passo 1, imagem 2 %32
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Battery Replacement: passo 2, imagem 1 %32
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Battery Replacement: passo 3, imagem 1 %32
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
Conclusão
To replace the battery, fit it in the slot, then close and lock the door.
Tyler
Membro desde: 04/22/14
569 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-55, Amido Spring 2014 Membro de Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
Membros da 4
Autoria de 31 guias
Um comentário
I’ve done this about a million times. :)
Martin Hurley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,978
