Ir para o conteúdo principal
Sony NEX-5T SD Card Replacement
O que você precisa
  1. Sony NEX-5T SD Card Replacement, SD Card: passo 1, imagem 1 %32 Sony NEX-5T SD Card Replacement, SD Card: passo 1, imagem 2 %32 Sony NEX-5T SD Card Replacement, SD Card: passo 1, imagem 3 %32
    • Make sure to turn the cameras power switch to off before beginning this step.
    • Begin by holding the camera upside down with the bottom facing you. Identify the housing for the SD card, and battery.
    • You will use your other hand to slide the lock switch to this housing to the right. This will release the cap, allow it to come upwards.
  2. Sony NEX-5T SD Card Replacement: passo 2, imagem 1 %32 Sony NEX-5T SD Card Replacement: passo 2, imagem 2 %32 Sony NEX-5T SD Card Replacement: passo 2, imagem 3 %32
    • Now that the cap to the battery and SD card housing is open, the SD card is visible.
    • You will need to press down on the SD card until you hear a click. Release the SD card and it will now be available to remove.
    • Grip the SD card and pull it out of the SD card slot.
  3. Sony NEX-5T SD Card Replacement: passo 3, imagem 1 %32 Sony NEX-5T SD Card Replacement: passo 3, imagem 2 %32 Sony NEX-5T SD Card Replacement: passo 3, imagem 3 %32
    • To reinsert the SD card place it in its housing.
    • You will then need to push down on the SD card until you hear a click.
    • To ensure the SD card is in place you can visually inspect it. The SD card should be flush with the housing.
  4. Sony NEX-5T SD Card Replacement: passo 4, imagem 1 %32 Sony NEX-5T SD Card Replacement: passo 4, imagem 2 %32 Sony NEX-5T SD Card Replacement: passo 4, imagem 3 %32
    • You may now close the housing for the SD card and battery.
    • Close the cap and while holding it down slide the locking tab to the left. This step should lock the cap in place.
    • Your SD card is now safely in place and you may turn your device on.
Linha de Chegada
Robert Phillips
Membro desde: 03/02/17
321 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S13-G2, Cagle Spring 2017 Membro de USF Tampa, Team S13-G2, Cagle Spring 2017
USFT-CAGLE-S17S13G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 24
Duração total: 868
