Ir para o conteúdo principal
Sony NEX-5T Motherboard
O que você precisa
  1. Sony NEX-5T  Motherboard, Battery: passo 1, imagem 1 %32
    • Open the battery compartment by sliding the lock to the right.
  2. Sony NEX-5T  Motherboard: passo 2, imagem 1 %32
    • Push in the blue lever.
    • The battery is on a spring so make sure you have control over it, or it might fly out.
  3. Sony NEX-5T  Motherboard: passo 3, imagem 1 %32 Sony NEX-5T  Motherboard: passo 3, imagem 2 %32
    • Pull the battery out.
  4. Sony NEX-5T  Motherboard, SD Card: passo 4, imagem 1 %32 Sony NEX-5T  Motherboard, SD Card: passo 4, imagem 2 %32 Sony NEX-5T  Motherboard, SD Card: passo 4, imagem 3 %32
    • Make sure to turn the cameras power switch to off before beginning this step.
    • Begin by holding the camera upside down with the bottom facing you. Identify the housing for the SD card, and battery.
    • You will use your other hand to slide the lock switch to this housing to the right. This will release the cap, allow it to come upwards.
  5. Sony NEX-5T  Motherboard: passo 5, imagem 1 %32 Sony NEX-5T  Motherboard: passo 5, imagem 2 %32 Sony NEX-5T  Motherboard: passo 5, imagem 3 %32
    • Now that the cap to the battery and SD card housing is open, the SD card is visible.
    • You will need to press down on the SD card until you hear a click. Release the SD card and it will now be available to remove.
    • Grip the SD card and pull it out of the SD card slot.
  6. Sony NEX-5T  Motherboard: passo 6, imagem 1 %32 Sony NEX-5T  Motherboard: passo 6, imagem 2 %32 Sony NEX-5T  Motherboard: passo 6, imagem 3 %32
    • To reinsert the SD card place it in its housing.
    • You will then need to push down on the SD card until you hear a click.
    • To ensure the SD card is in place you can visually inspect it. The SD card should be flush with the housing.
  7. Sony NEX-5T  Motherboard: passo 7, imagem 1 %32 Sony NEX-5T  Motherboard: passo 7, imagem 2 %32 Sony NEX-5T  Motherboard: passo 7, imagem 3 %32
    • You may now close the housing for the SD card and battery.
    • Close the cap and while holding it down slide the locking tab to the left. This step should lock the cap in place.
    • Your SD card is now safely in place and you may turn your device on.
  8. Sony NEX-5T  Motherboard, Motherboard: passo 8, imagem 1 %32
    • Remove the 3.5 mm exterior-side screw.
  9. Sony NEX-5T  Motherboard: passo 9, imagem 1 %32
    • Remove the 3.5 mm bottom screw from the battery compartment.
  10. Sony NEX-5T  Motherboard: passo 10, imagem 1 %32
    • Pry off the front-side cover with the small plastic spudger.
    • There is a adhesive holding the front-side cover to the camera frame, so more force may be necessary to remove it. Be careful as to not break the cover while prying.
  11. Sony NEX-5T  Motherboard: passo 11, imagem 1 %32
    • Remove the 3.5 mm bottom screws.
  12. Sony NEX-5T  Motherboard: passo 12, imagem 1 %32 Sony NEX-5T  Motherboard: passo 12, imagem 2 %32
    • Open the USB cover on the side of the camera.
    • Remove the 3.5 mm USB side screws.
  13. Sony NEX-5T  Motherboard: passo 13, imagem 1 %32
    • Remove the 4mm screws at the back of the battery compartment.
  14. Sony NEX-5T  Motherboard: passo 14, imagem 1 %32
    • Remove the 3.5 mm top flash-mount screw.
  15. Sony NEX-5T  Motherboard: passo 15, imagem 1 %32
    • Flip the screen up.
    • Pry the top cover off with the small plastic spudger.
  16. Sony NEX-5T  Motherboard: passo 16, imagem 1 %32 Sony NEX-5T  Motherboard: passo 16, imagem 2 %32
    • Pry the top part rear cover off with plastic spudger.
    • Flip the camera so the sensor faces down and push up on the rear cover from the battery compartment.
  17. Sony NEX-5T  Motherboard: passo 17, imagem 1 %32
    • Remove the 2.25 mm tripod mount screws.
  18. Sony NEX-5T  Motherboard: passo 18, imagem 1 %32 Sony NEX-5T  Motherboard: passo 18, imagem 2 %32
    • Remove the 2.25 mm side lanyard mount screw.
    • Pull the lanyard mount to remove.
  19. Sony NEX-5T  Motherboard: passo 19, imagem 1 %32
    • Remove the 2.25 mm screws from the top.
  20. Sony NEX-5T  Motherboard: passo 20, imagem 1 %32
    • Using the tweezers, pull out the rubber grommet.
    • There is nothing holding the grommet in other than friction.
    • The grommet is small, don't lose it.
  21. Sony NEX-5T  Motherboard: passo 21, imagem 1 %32
    • Pull the lead that was under the grommet out from the frame.
  22. Sony NEX-5T  Motherboard: passo 22, imagem 1 %32 Sony NEX-5T  Motherboard: passo 22, imagem 2 %32
    • Flip the rotary selector and controls up over the top.
    • Holding the controls in place, pull the two frame pieces apart.
    • There is a connection between the motherboard and the LCD screen still attached to both halves, so don't pull to hard.
  23. Sony NEX-5T  Motherboard: passo 23, imagem 1 %32
    • Disconnect the connection between the motherboard and LCD screen by pulling out the connector in the direction of the arrow.
  24. Sony NEX-5T  Motherboard: passo 24, imagem 1 %32 Sony NEX-5T  Motherboard: passo 24, imagem 2 %32
    • Using the tweezers, disconnect the metal lead at the top of the motherboard by pulling up.
  25. Sony NEX-5T  Motherboard: passo 25, imagem 1 %32 Sony NEX-5T  Motherboard: passo 25, imagem 2 %32 Sony NEX-5T  Motherboard: passo 25, imagem 3 %32
    • Disconnect the two top-right connectors by pulling them up towards the top.
  26. Sony NEX-5T  Motherboard: passo 26, imagem 1 %32 Sony NEX-5T  Motherboard: passo 26, imagem 2 %32
    • Disconnect the two connectors on the right by pulling them to the right.
  27. Sony NEX-5T  Motherboard: passo 27, imagem 1 %32 Sony NEX-5T  Motherboard: passo 27, imagem 2 %32
    • Using the tweezers, flip open the black door on the large connector on the bottom.
    • Remove the connector by pulling it away from the motherboard.
  28. Sony NEX-5T  Motherboard: passo 28, imagem 1 %32 Sony NEX-5T  Motherboard: passo 28, imagem 2 %32
    • Using the tweezers, flip open the door on the smaller connector.
    • This is the same process for from the previous step.
  29. Sony NEX-5T  Motherboard: passo 29, imagem 1 %32 Sony NEX-5T  Motherboard: passo 29, imagem 2 %32
    • Disconnect the connector that goes through the motherboard.
    • There is no door on this connector.
  30. Sony NEX-5T  Motherboard: passo 30, imagem 1 %32
    • Remove the 4 mm screws securing the motherboard to the frame.
  31. Sony NEX-5T  Motherboard: passo 31, imagem 1 %32 Sony NEX-5T  Motherboard: passo 31, imagem 2 %32
    • With the tweezers, remove the metal speaker cover.
    • Pull the speaker out of the frame.
    • Remember how the wires lay back in the frame for reassembly.
  32. Sony NEX-5T  Motherboard: passo 32, imagem 1 %32
    • Flip the motherboard up and disconnect the connector on the back.
    • Seperate the motherboard from the frame.
Conclusão
William Kleinman
Membro desde: 03/02/17
301 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S13-G2, Cagle Spring 2017 Membro de USF Tampa, Team S13-G2, Cagle Spring 2017
USFT-CAGLE-S17S13G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 780
