Ir para o conteúdo principal
Sony NEX-5R Rear Case Replacement
O que você precisa
  1. Sony NEX-5R Rear Case Replacement, Front Case: passo 1, imagem 1 %32 Sony NEX-5R Rear Case Replacement, Front Case: passo 1, imagem 2 %32
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Rear Case Replacement: passo 2, imagem 1 %32
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Rear Case Replacement: passo 3, imagem 1 %32 Sony NEX-5R Rear Case Replacement: passo 3, imagem 2 %32
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Sony NEX-5R Rear Case Replacement, Rear Case: passo 4, imagem 1 %32
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Sony NEX-5R Rear Case Replacement: passo 5, imagem 1 %32
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Sony NEX-5R Rear Case Replacement: passo 6, imagem 1 %32
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  7. Sony NEX-5R Rear Case Replacement: passo 7, imagem 1 %32
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Sony NEX-5R Rear Case Replacement: passo 8, imagem 1 %32 Sony NEX-5R Rear Case Replacement: passo 8, imagem 2 %32
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  9. Sony NEX-5R Rear Case Replacement: passo 9, imagem 1 %32
    • The back case should now be removed and look like this.
Conclusão
Uma outra pessoa concluiu este guia.
Emily Trujillo
Membro desde: 04/08/14
1.114 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-9, Regan Spring 2014 Membro de Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 2,393
