Ir para o conteúdo principal
Sony NEX-5R Main Navigation Button Replacement
O que você precisa
  1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: passo 1, imagem 1 %32
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  2. Sony NEX-5R Main Navigation Button Replacement: passo 2, imagem 1 %32
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  3. Sony NEX-5R Main Navigation Button Replacement: passo 3, imagem 1 %32
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  4. Sony NEX-5R Main Navigation Button Replacement: passo 4, imagem 1 %32
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  5. Sony NEX-5R Main Navigation Button Replacement: passo 5, imagem 1 %32 Sony NEX-5R Main Navigation Button Replacement: passo 5, imagem 2 %32
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  6. Sony NEX-5R Main Navigation Button Replacement: passo 6, imagem 1 %32
    • The back case should now be removed and look like this.
  7. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: passo 7, imagem 1 %32
    • Use spudger to pull the lead out from its housing.
  8. Sony NEX-5R Main Navigation Button Replacement: passo 8, imagem 1 %32 Sony NEX-5R Main Navigation Button Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
  9. Sony NEX-5R Main Navigation Button Replacement: passo 9, imagem 1 %32 Sony NEX-5R Main Navigation Button Replacement: passo 9, imagem 2 %32
    • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
Conclusão
3 outras pessoas executaram este guia.
Emily Trujillo
Membro desde: 04/08/14
1.153 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-9, Regan Spring 2014 Membro de Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 41
Ao todo: 4,560
