Ir para o conteúdo principal
Sony NEX-5R Lens Mount Replacement
O que você precisa
  1. Sony NEX-5R Lens Mount Replacement, Lens Mount: passo 1, imagem 1 %32 Sony NEX-5R Lens Mount Replacement, Lens Mount: passo 1, imagem 2 %32
    • Hold lens and camera securely with two hands.
    • With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
  2. Sony NEX-5R Lens Mount Replacement: passo 2, imagem 1 %32
    • Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
    • Make sure to keep track of these screws and not misplace them.
  3. Sony NEX-5R Lens Mount Replacement: passo 3, imagem 1 %32
    • Remove the silver plate by gently pinching with your fingers.
  4. Sony NEX-5R Lens Mount Replacement: passo 4, imagem 1 %32
    • Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
  5. Sony NEX-5R Lens Mount Replacement: passo 5, imagem 1 %32
    • Using the tweezers, grab the thin silver ring and lift up.
  6. Sony NEX-5R Lens Mount Replacement: passo 6, imagem 1 %32
    • The camera mount should now be barren and look like this.
Conclusão
Uma outra pessoa concluiu este guia.
Emily Trujillo
Membro desde: 04/08/14
1.114 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-9, Regan Spring 2014 Membro de Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 2,466
