Introdução
This guide provides a step-by-step approach to safely removing the back cover of the Sony MVC-FD200. It ensures that users can access the internal parts of the camera for troubleshooting or replacement without harming the device. Whether you are replacing a faulty screen, cleaning the internal parts, or making other adjustments, this guide will help you navigate the process effectively.
O que você precisa
Using your finger, slide the tab on the battery door up to release the battery latch.
Turn the camera so that the top is facing down towards the table.
Using the Phillips #00 screwdriver, remove all 2.0 mm screws with the arrows facing towards them.
