Ir para o conteúdo principal
Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement
O que você precisa
  1. Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement, Cushion: passo 1, imagem 1 %32
    • Begin by laying the headphones down flat on a surface.
    • Make sure that the headphone speakers are facing upward.
    • Be sure to check that the headphones are not plugged into any devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement: passo 2, imagem 1 %32
    • Using the plastic opening tools, gently pry the speaker from the headphone's base.
    • There will be some tearing involved, but this is necessary to remove the original cushion.
    • The cushion is bonded to the headphones with a circular adhesive strip. If you plan on reusing the cushion, try to keep the adhesive attached to the cushion during removal. This way the cushion can be easily re-attached to the headphones after repair.
Conclusão
8 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 4,533
