Introdução
The motherboard is the brain of your microcassette-corder. Following the steps in this guide will allow you to remove the motherboard and install a new one, saving your microcassette-corder.
Ferramentas
Peças
Nenhum componente especificado.
Find the arrow on the battery cover on the back of the device.
While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
Next, twist it to the side as shown in the second picture. The lid should simply snap off.
Using tweezers, pull upward on the black tape which secures the wires.
Removing this tape allows you to move the wires out of the way for the next step.
If the replacement motherboard does not have the wire battery terminals attached, desolder the two battery connections on the motherboard.
Leave the wire battery terminals in place.
If the replacement motherboard has battery terminals attached, the connections do not need to be desoldered.
Uma outra pessoa concluiu este guia.
Um comentário
Buenas tardes,podrían colaborar me con las referencias de las resistencias de control de 2.4 y 1.2 del motor o guiarme donde puedo adquirir esta información. bendiciones mil gracias. Antonio
