Ir para o conteúdo principal
Sony M-430 Microcassette-Corder Microphone Replacement
O que você precisa
  1. Sony M-430 Microcassette-Corder Microphone Replacement, Battery: passo 1, imagem 1 %32
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Microphone Replacement: passo 2, imagem 1 %32 Sony M-430 Microcassette-Corder Microphone Replacement: passo 2, imagem 2 %32
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Microphone Replacement, Back Cover: passo 3, imagem 1 %32 Sony M-430 Microcassette-Corder Microphone Replacement, Back Cover: passo 3, imagem 2 %32
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Potential for device damage: be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Microphone Replacement: passo 4, imagem 1 %32 Sony M-430 Microcassette-Corder Microphone Replacement: passo 4, imagem 2 %32
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Microphone Replacement: passo 5, imagem 1 %32
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment). It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Microphone Replacement: passo 6, imagem 1 %32
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  7. Sony M-430 Microcassette-Corder Microphone Replacement, Microphone: passo 7, imagem 1 %32
    • The microphone is the silver circular part above the buttons on your device.
    • A black and a red wire connect the microphone to the motherboard as shown in the bottom left of the picture.
  8. Sony M-430 Microcassette-Corder Microphone Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • The wires are held down with a piece of black tape.
    • Remove the tape with a pair of tweezers.
    • Potential for device damage: try not to pull the wires, as they might tear loose from their soldering connections
  9. Sony M-430 Microcassette-Corder Microphone Replacement: passo 9, imagem 1 %32
    • Desolder the two connections between the wires and the motherboard. Make sure that the two solder points do not melt together.
  10. Sony M-430 Microcassette-Corder Microphone Replacement: passo 10, imagem 1 %32
    • Now that the wires are disconnected from the motherboard, you can simply pull the mic out, away from the top of the device.
    • Potential for device damage: be careful to not detach the mic from its wires, as the connection between the wire and the mic itself is delicate.
Conclusão
Matt Teare
Membro desde: 01/20/12
35 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-34, Amido Winter 2012 Membro de Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,398
