Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The mechanism deck is responsible for turning the tape at the correct speed so that your recordings record and playback properly. This guide shows you how to replace the mechanism deck and get your microcassette-corder back in working order.
O que você precisa
Using a spudger, apply pressure towards the back corner of the cassette compartment to the plastic tab directly behind the gold cone.
Pushing the tab allows the hinge to be separated from the body of the device.
Find the arrow on the battery cover on the back of the device.
While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
Next, twist it to the side as shown in the second picture. The lid should simply snap off.
Using tweezers, pull upward on the black tape which secures the wires.
Removing this tape allows you to move the wires out of the way for the next step.
If the replacement motherboard does not have the wire battery terminals attached, desolder the two battery connections on the motherboard.
Leave the wire battery terminals in place.
If the replacement motherboard has battery terminals attached, the connections do not need to be desoldered.
First, remove the buttons from the mechanism deck so that you can remove it from the case.
Find the tabs on each button.
Push the tab with a spudger away from the metal connection.
Pull button away from the mechanism deck to remove it.
7 outras pessoas executaram este guia.
3 comentários
I would greatly appreciate receiving some info regarding where to get parts or a full mechanism deck replacement for Sony M-607V microcassette recorder. Also if it is possible to get a Service Manual with exploded views.
Thanks in advance for any help.
Hermann
